We contacted our gas supplier and they came and put about 30cms of insulation on top of what we had. It was covered by a grant at the time so the cost was nil.
Although the current grant programme has been deemed a failure I think it’s still in effect. So you’d probably pay much less than the cost. I would start with your gas supplier as there are fairly strict guidelines as to who can install under the current programme.
If their quote is too high you can still DIY. By then you will know what depth of insulation is recommended.
The funding programme for loft insulation has in the past been ECO - Energy Company Obligation. In the mid 2010s the eligibility was massively cut back and rates of insulation across the UK dropped off a cliff. Unless you are receiving a benefit (JSA, Universal Credit, etc etc) you won’t get ECO. Child Benefit is eligible for ‘dual measures’ - which I think is usually an insulation PLUS a new boiler under certain conditions. There are companies working on behalf of energy companies so you can simply google it to find companies. However beware the work can be sloppy - to get it signed off and get it recorded on a EPC there only needs to be insulation for 1 metre surrounding the loft hatch.
The top quality job for the loft is to incorporate air tightness and vapour control. Removing all insulation, putting heat/fire proof and air tight protection over downlighters and sealing around cable penetrations, and adding an insulated air tight loft hatch. Then you lay a vapour barrier membrane across and between the joists, and taping up the overlaps. Then after laying the insulatoin you put an airtight membrane over the top of the insulation to prevent air movement getting in or behind the insulation. Also ideally you would design wall insulation to be continuous with loft insulation. Example: Roof eaves: insulation & airtightness for a typical W. Yorkshire terraced house - YouTube
Most people don’t bother with this - I won’t in my current house - but this would be necessary for an AECB or Passivehouse standard retrofit.
Anyway the main step is adding up to 400mm of quilted insulation - mineral wool, glass wool and sheeps wool all have similar thermal properties. Sheeps wool and, I understand, some of the more expensive glass fibre, is nicer to handle. But the stuff permanently on special offer in B&Q is thermally as good as anything else. For all these materials you need to ensure it is not compressed, for example by objects resting on top. Building Reg in England requires a depth of 270mm, but the more the merrier. Joists are typically 6" deep = 150mm, so conventionally you put 1 150mm roll between the joists, and another 150mm roll across the joists. But you will get thermal benefit and good ROI on throwing an additional layer on top.
I experimented with rigid insulation but it is extremely difficult to get a airtight fit between the joists - avoid!
Important to make sure electrical cables have enough slack to rest on top of the insulation, otherwise you risk them overheating.
A detail I struggled with is at the walls where rafters meet joists and there isn’t 300mm of space so you risk a thermal bridge (cold spot) in the ceiling below by the wall, and you risk blocking ventilation which needs to be maintained around the rafters. See my comment about this here How to insulate a loft at the eaves
I have gone with these simple plastic inserts which maintain airflow while allowing you to push in more insulation than is otherwise possible. I’m planning to install on Monday so I’ll let you know if it doesn’t work out! Hambleside Danelaw HDURFT Universal Refurb Loft Tray Vent - Pack of 25 only £24.71
All this is from interest as a DIYer and AECB Carbonlite Retrofit course so professionals might provide more reliable advice.
Hi, I would suggest you do it as a DIY job unless you are very allergic to the stuff that is currently in place and I am going to disagree a little bit with the suggestions before.
Leave the current insulation in place unless you must plug holes for cables and downlighters.
Top up your current 100mm with as thick as you can pack in to just above the top of the joists. Cover the joists with a breather membrane (I spent £1/m2 for good tear strength and you can spend a lot more-). Staple down the breather membrane to joists and tape the overlaps for good measure. Breather membrane function is to act as a barrier to stop windwashing and convection currents that suck heat from low density insulation i.e. mineral/ glass/ sheep wooll. You then put another layer of insulation across the joists e.g. 200mm. Doing it this way increases insulation efficiency considerably and maintains breathability of the materials used.
When buying insulation check the coverage per pack/ retailer and convert to £/m2 as I found the same brand varied per retailer.
For the loft opening get a piece of solid foam board 100mm thick (lots of offcuts in Skips) and combine with Gapotape to fit behind loft panel – because it is friction fitted it can be removed and replaced for access many times.
Thanks all, useful stuff, planning on stripping out all the random insulation and doing a proper job with breather membrane etc and 400mm insulation. Note the comment about the cables- I’ve seen discussions in other places saying that if it is just lighting cables they should be OK under the insulation?- just wondering as I have no electrical background but I’m not sure there will be 400mm slack in the cables in my loft- then would it be an expensive job for an electician to do something about that?
@pwshk planning on doing it ourselves- will reuse if its OK. Was wondering if I could just use some open conduit to give some space between any lighting cables and the insulation, then the breather membrane and insulation on top?
Sorry @Lisa_Varey I don’t now what’s best but I’m sure somebody here will be able to assist.
I’m leaning towards topping up the existing 100mm with another 200mm to tide me over until I can afford getting a professional in to evaluate and do better job. That said I think the extra 200mm will be the best bang for my buck - I had a thermal cam up their last winter and it didn’t look too bad.
In a low energy new build there is a void between plasterboard and insulation for services. Could you emulate that? Otherwise I don’t see why oversize conduit shouldn’t be used.
Topping up is generally the best answer where the old insulation is in good order. Fill in any gaps you find first and then add the new layer.
Your suggested 1:2 ratio is interesting for another reason too. I’m sure that somewhere I read that you can add an airtight membrane over, rather than under, the existing insulation so long as the membrane is no more than 1/3 up the final buildup. More than that and the cooler membrane can cause moisture to condense in the insulation.
Regarding the airtight membrane: the more insulation you have the cooler your loft in winter. The cooler loft air will increase the relative humidity of air percolating up through the insulation thus making condensation in the loft more likely. An airtight layer will reduce this and if it is properly sealed to the ceiling/wall should eliminate the problem .
If you increase the airtightness of the house you are likely to need increased controlled ventilation.
I invested in sheepwool and I don’t regret it one bit despite the cost - about £1800 in all.
It was lovely to put down - being fully recyclable it has a minimal carbon cost compared to all other insulations. Feeling quite strongly about funding anything oil , life cycles of products through to waste were my main reasons for investing in sheepwool - it doesn’t contain any plastics , offgas or mined material waste.
As well as my ethics in purchase I discovered that sheepwool is unique having hydroscopic/ breathable qualities - it can absorb up to a third of its weight in moisture and dry out with the seasons. It’s a perfect natural material to use with our brick Victorian semi that needs to ‘breath’ with the seasons while we eradicate draughts and keep warm.
Currently we’re just topping up to 30 cm and adding a wind shear layer over the top.
I don’t have to put on any protective gear when laying the sheepwool.
They also do a 9mm underlay for carpets - we purchased that as an option to insulate our floor from above because we can’t afford to take up the boards to insulate underneath as they are nailed down and split when you lift them.
This is the best way we have found to be practical moving forward with our spending, embodied carbon in materials and in having a healthy low energy home.
Some years ago the driver of a sheep transporter was prosecuted for having an overweight cargo. He got away with it because he could show that the weight was ok when the sheep were loaded but he had driven through torrential rain and the sheep’s wool had absorbed a load of water.
