Home Assistant Show and Tell
Hi can anyone help please? I set up home assistant with phoscon & aqara sensors following Matt’s excellent guide. Been working great for two years but now can’t connect. ERR_CONNECTION_REFUSED.
Limit of my understanding is to reboot non router, turn off/on pi, but that doesn’t work!
Any (simple) suggestions appreciated. Ta
I had this a while ago - updated all the OS / Software and rebooted and then had to remove and then re add the sensors to Phoscon and that fixed it - I think it is “just one of those things…”
Matt’s guide is excellent mind - kept me busy in lockdown!
Thanks, I guess that’s like starting again from scratch? Will all the data gathered so far be lost? Matt’s guide is so good that I don’t really have a clue as to what is really happening in the background!
As long as you use the same names for all the sensors/groups it should be fine.
Reviving this topic now that a new version of the HEMS / Home Assistant has been deployed
I’m looking for some help with setting up the HEMS.
Solar PV is being installed next week. Does anyone have any automations or advice on how I set this up to charge my EV.
Also what would be needed to be able to use the solar to power the immersion on the water tank bearing in mind I already have solar thermal.
You’ll need an MyEnergi Eddi to do the Solar PV diversion to your hot water tank - as long as there are seperate theormstats for both the immersion and the piped water heating from the solar thermal you should be fine.
