Solar Thermal for Domestic Hot Water
Hi - Does anyone have any experience of using Solar Thermal to heat hot water in a domestic hot water tank. I’m trying to get my head round the options here vs just using cheap electricity (5p per unit) to run an immersion heater overnight… Its all part of a much bigger project where I basically need to retrofit a new build house to have some decent green tech in it!
Thoughts welcome…
Edward
I have had solar hot water since before RHI and am generally happy with it. I recommend oversized collectors if possible and and oversized water cylinder. Between them these allow plenty of prewarmed water on cooler days and storage of hot water on hot days to contribute to requirements on a following cooler day.
You can’t store domestic hot water for long but depending on your circumstances you might get some benefit for up to three days from one really hot and sunny one.
The disadvantages of solar are the need for occasional service (mine needed a new pump after 8 years) and that once the water is as hot as you dare they have no additional function, whereas PV may be relatively inefficient but you can export excess.
On the subject of “as hot as you dare” you ought to have a safety mixer to reduce the flow temperature. As well as being safer, by reducing deltaT you also reduce pipe losses.
