Retrofit advice for a Tameside home
Hi everyone,
I recently attended a Carbon Coop Retrofit for beginners session and am looking for advice and recommendations for a retrofit project, insulating my home and replacing my gas boiler with an air source heat pump.
I moved into a small ‘2 up – 2 down’ mid terrace 19th century house, built with solid stone walls, a few months ago, I’m the home owner. The building isn’t listed and I don’t live in a conservation area.
It’s in ok condition, the roof and chimney don’t leak, there are no signs of damp, the walls could be tidied up but nothing major. The double glazed windows and doors seem to be reasonable quality, I’m guessing they’re approximately 5-10 years old.
The front of the terrace faces SSE, the rear NNW.
My objective is to reduce energy use and carbon emissions, without using a lot of ‘eco-unfriendly’ materials. I appreciate deciding which insulation materials to use, balancing the reduced pollution impacts with the most effecitve energy saving performance and fewest practical drawbacks, isn’t straightforward.
Overall I don’t want to needlessly ‘modernise’ or remove functional parts of my home, I want to keep material and energy use to a minimum. For example, replacing pretty well performing double glazing with triple glazing, for what might be a marginal benefit. This is partly because of wanting to reduce waste and unnecessary production and partly because of my very limited budget.
My financial constraints mean I need to try to get as much of the work as possible funded, and where that isn’t possible, probably do it myself (not including fitting the heat pump.)
My GMCA ECO4 application was rejected, due to cavity wall insulation not being possible, meaning the works would fail to meet the minimum EPC uplift criteria.
However, after this, a worker from Energyworks visited, and they suggested I contact 0800 Repair. Having done so, and going through the application process with them, they should be fitting loft insulation and a few other smaller interventions, within one of the funding schemes, sometime in the next couple of months or so.
I’m coming to all this from a pretty uniformed position, I’m hoping people here will be able to help. I don’t fancy spending a lot of money on a survey and I can’t afford to pay someone to do the work, but I also don’t want to make a mess of it. Though I’ve no experience fitting insulation, I’m generally able to turn my hand to things.
I think part of the ‘plan’ will be to install wall insulation, both to reduce heat loss and because my understanding is that, if I want to get an air source heat pump fitted, I need to get that done.
So I’m wondering what to do about wall insulation.
The SSE facing wall of the stone built terrace isn’t an appropriate location for EWI, primarily because of the appearance of the ‘front’ of the terrace as a whole, considering my neighbours. This wall isn’t shaded by other buildings or trees, so is also perhaps somewhat less of a heat loss challenge, especially with any sunny days. So I’m thinking to fit internal insulation on this wall, I have enough space in these rooms to accommodate this.
The back of the terrace isn’t a location that my neighbours are likely to have concerns over any ‘sympathetic’ changes in the appearance of my house. (Though I’m guessing the edge of where anything is fitted needs to be carefully positioned and finished, where it joins my neighbour’s walls. I’ve already chatted with them about it, even though it’s probably going to be spring 2025 before I can start.)
This NNW facing wall doesn’t get any sun, except around mid summer. My thinking is to fit external wall cladding here. I have very limited space in the rooms at the back of the house and internal cladding would mean a lot more work, moving everything in the bathroom and kitchen.
It will require quite a bit of prep of the wall, guttering, soil pipe, possibly extending the roof line a little, and so on. Nothing too drastic. I have access to a small scaffolding tower and have some ‘DIY’ experience.
How hard can it be? :smiley:
I’m assuming that the insulation has to be installed before anyone would agree to fit the Heat Pump, and that this would be best from a practical point of view too, despite having to drill through recently completed work?
It would be great to speak to someone who has experience of fitting internal and external cladding. Ideally finding someone who could visit and give me some pointers on the specifics of my house would be incredibly helpful. For example, the NNW external wall is quite rough/irregular, I need to know if in preparation I need to create a more even surface to fix the insulation material to, and whether I might need to re-point with a lime mortar, replacing what might be the existing ordinary cement mortar…?
During the retrofit for beginners presentation at the Carlton Club, an example was shown of wood fibre external cladding that had recently been fitted to a house in Manchester.
I’m guessing the material was something like this:
It would be very useful to know more about the pro’s and con’s of different materials and their suitability for my house and the differences in method of fixing, for example using ‘breathable’ adhesive for my solid stone walls.
It’s perhaps worth mentioning that it looks like 0800 Repair do fit cladding and heat pumps, though it looks like they possibly only offer this in the North East of England; External Wall Insulation Durham & North East| Outside Wall Insulation | 0800 Repair
It might be that I can organise for getting the ‘whole job’ done by them, possibly incorporating more funding, for example from the boiler upgrade scheme that runs to April 2025? Incidentally, does anyone here have any experience with 0800 Repair or know of any local alternatives who could possibly do the work instead?
Does anyone here have recommendations regarding getting air source heat pumps fitted? I think there is enough space to install one at the back of the house on the little paved area I have and my gut feeling is that the existing radiators are probably sufficient, though I’ve not actually used my heating yet since I moved here in May. It was mentioned at the beginner’s retrofit session that reducing flow temp to 45-50 deg would give you a sense of whether the existing radiators and plumbing would work effectively with a heat pump, I’m sure I’ll get chance to test that over the coming months.
Thanks for your patience reading through all this, Hamish :slight_smile:
Hi @hamishrh1 and welcome to the forum.
First of all I can assure you that wall insulation is not a requirement for a heat pump (HP), but it does help.
Heat pumps are (or should) be specified according to a heat loss calculation for your house and also each room separately. The per room calculations are more for radiator sizing whilst the whole house is for the HP itself.
Insulating after fitting the heat pump means that your heat loss calculations will be too high and the HP. Most heat pumps modulate down to about ⅓ of their maximum rating, So this isn’t disastrous but you will get inefficiencies as the start and end of the heating season. To avoid this as much as possible you need to go for the lowest power HP that you can get away with.
If you can find a HP installer that gives free assessments I suggest that you get one sooner rather than later and discuss with the installer what is needed to reduce the HP size required. This will help you prioritise the work needed.
Extending the roof line on a terraced house can be done but beware leaks where the roof lines meet. You will not be popular if your runoff ends up going through your neighbours’ ceilings. If theirs runs through your ceiling then you have created your own issue and have to deal with it.
Hopefully you have a good idea about fitting IWI yourself but feel free to ask more before you start. Remember to insulate between floors and ceilings, down to the DPC and ideally between rooms. Finally the window and door reveals are an absolute must, in fact more important than anywhere else as the thermal thickness of your walls at window and door frames is only the thickness of the frame.
I really can’t recommend DIY EWI. You run the risk of severe structural damage if water gets into the insulation.
Does your house actually have a DPC? Older ones may not. Is there any risk of flooding, including flash flooding? Before answering the flooding consider drains that may not be in your curtilage and the predicted effects of climate change.
You can still have EWI if there is a medium risk of flooding but the lower insulation bats need to be a waterproof non-rotting material. Above them your suggested wood fibre may be adequate.
EWI needs to go down to the footings, particularly for properties with solid floors and then adequate drainage installed against it. Is there room? What is the ground surface made of?
You have something to think about here, so I’ll stop there and other members can have their say.
Hi Tim,
Thanks for taking the time to reply and provide useful food for thought.
I’ll find an HP installer soon to hopefully come and have a look (for free… :stuck_out_tongue: ).
Does anyone have any recommendations? I was thinking of contacting A Mellor plumbing and heating (Rochdale) to start with.
Re the roof line, I was thinking of using a verge trim at the top to avoid having to mess with it, it’ll probably need some creativity to fit it as high as possible and securely fix the gutter and keep that working properly.
Thanks for the reminder on the reveals, I have been looking at the different thicknesses of board available for that purpose. Also the reminder on insulating between floors and ceilings.
I don’t think there is a DPC, I was thinking of using dry rods.
I don’t think there’s much risk of flooding, we’re on a pretty steep hill and my neighbours who’ve been here 20+ years have not experienced, or heard of any such events. However it’s not completely impossible for there to be some sort of flash flood that could run past the back of the house, so I will take that into account.
It’s stone flagged at the back, about 150mm below the level of the solid internal floor.
I’ll update as things go along, for anyone with experience, or thinking of doing something similar.
Hamish
I’ve just found this article while looking for examples of verge trim with EWI. It’s a very well known case but not specific to the trims.
See page 37 of this document:
ii. interfaces with roofs at eaves and verges (where metal or plastic cappings and trims shall not be used)
Does anyone have recommendations for/experience with, internal and external insulation products/suppliers, that could be suitable for my home?
I was looking at this for example;
Also, recommendations for heat pump installers, who are well established, relatively local and not likely to be gone in a couple of years time?
So far, I’ve contacted A Mellor’s of Rochdale for a quote;
Interaction has been good so far.
Thanks
H
Hi Hamish
You may have got the recommendation for A Mellor from one of my previous posts. I can still recommend them, after my 2 year service. I have wood fibre IWI installed in my Victorian semi and can share experience but I can’t recommend an installer. More info on the house is at my website Julian Tomlin - Victorian Semi - Julian Tomlin. Feel free to get in touch.
Julian
Returning to this subtopic, yesterday I found these two diagrams in a masterclass given by Passivhaus Trust. I thought of you and immediately screenshot them before they disappeared.
Thanks Tim.
I recently contacted ‘Back to Earth’. Curious what they have to say.
Hamish
Hi everyone, since posting the previous messages a couple of years ago, I’ve had an air source heat pump fitted with a Heat Geek mini store, (about 18 months ago), all of which seems to be working well.
Last autumn I retrofitted internal wall insulation to the front (South facing) wall of my small mid terrace home. I got the materials from Womersley’s (https://www.womersleys.co.uk/) using the lime green /warmshell products. I’m happy with result despite my dodgy plastering skills!
The loft was also topped up to 300mm, which I adjusted / added to myself, improving ventilation (I hope) whilst extending it as far over the thick external walls as I could manage. The improvement is noticeable and I’ve not noticed any condensation, damp or cold spots yet.
The next step I think is to look at the back (North facing) wall. It’s quite a sheltered spot, is rarely exposed to driving rain, very low risk of flood. For various reasons I don’t want to fit insulation internally and am looking at external cladding, probably using Womersley’s lime and wood fibre products again.
There are several challenges, what to do about the roof line, gutter, service pipes etc. I may well have to replace the window frames as there’s almost no room to insulate the reveals…(though it may be possible to be creative there… and I’m happy to insulate the internal reveals.)
I can borrow some scaffolding and feel reasonably confident that I can do the job but it would be a massive help to talk to people who’ve done it themselves, knowing all the tips and tricks would make a big difference.
It’s a bit of an ask, but is anyone up for / can anyone recommend someone, I could visit and talk this over with, see their handy-work, ideally within / close to Greater Manchester?
Thanks
Hamish
Well done on your achievements so far. I suggest you put yourself down to borrow one of Carbon Coop’s thermal cameras to look both for cold spots on the inside and hot spots on the outside.
Both are best done on a cold night in winter.
I’m afraid I have no recommendations on the EWI.
