Insulate Cold Strip Along Ceiling?
Yes, looks good, altho probably this one here? - the sloping-strip of ceiling (and presumably, the whole ceiling) appears to be a continuous mortar/plaster-type substance, definitely not plasterboard, and about 12mm- 15mm thick, with hollowness behind, ie, needs an expander-bolt type of mechanism:
Screw-set Insulation Fixings for wood fibre insulation boards (ecomerchant.co.uk)
Hi Mike. How did you get on with the curve ceiling cold spot issue. I have the same problem with my property and needs to be rectified.
