# Thermal Imaging - as a tool for retrofit evaluation
**URL:** <https://community.carbon.coop/t/thermal-imaging-as-a-tool-for-retrofit-evaluation/35>\
**Category:** Home Retrofit\
**Created:** [15 October 2020 13:00 UTC](https://community.carbon.coop/t/thermal-imaging-as-a-tool-for-retrofit-evaluation/35 "2020-10-15T13:00:43Z")\
**Posts on this page:** 1\
**Showing post:** 49
<div class="post-metadata">
**Author:** ![Christopher\_Williams](https://community.carbon.coop/letter_avatar_proxy/v4/letter/c/d9b06d/32.png) [@Christopher\_Williams](https://community.carbon.coop/u/Christopher_Williams)\
**Post date:** [20 January 2022 10:42 UTC](https://community.carbon.coop/t/thermal-imaging-as-a-tool-for-retrofit-evaluation/35/49 "2022-01-20T10:42:00Z")
</div>
Hi there,
I have just borrowed the thermal camera from the carbon co-op. Its been great to spot how terrible my loft insulation was as well as identify the cold spots around my wood burner.
I could do with some advice/interpretation on how the external of my house has been performing. I’ve previously posted how I’ve had issues with my cavity walls ([Bubble wrap foil - Cavity Wall Insulation - What can be done? ([Bubble wrap foil - Cavity Wall Insulation - What can be done?](https://community.carbon.coop/t/bubble-wrap-foil-cavity-wall-insulation-what-can-be-done/326)) Well I managed to get outside to check the house, I was expecting the walls to be quite warm but they “looked” great compared to the windows (they are 20 years old to be fair) but am I reading this right? In my head, if I had a well-rounded house then the walls and windows should be roughly the same shade colour i.e. low heat loss, but to see such differentials am I to conclude that most of my heat is escaping via the windows and not the walls at the moment? FYI House was 19 degrees and it was -1 degrees outside
 ![FLIR1415](https://community.carbon.coop/uploads/default/original/1X/efa26875bc182b73acd6ddf88350a89eba967bb8.jpeg)
 ![FLIR1417](https://community.carbon.coop/uploads/default/original/1X/bf4e3eefbaf8cd3811f5930cf5e7ffb7ad137d6f.jpeg)
 ![FLIR1419](https://community.carbon.coop/uploads/default/original/1X/c585e243958a6468f5da9c2015b56a74788b54f3.jpeg)
 ![FLIR1423](https://community.carbon.coop/uploads/default/original/1X/787ffc806a0cb1ad11113a5cc427ae832322180e.jpeg)
 ![FLIR1425](https://community.carbon.coop/uploads/default/original/1X/11a0d51b8f4cd224c14719daba1a76f914e37f84.jpeg)
_[View the full topic](https://community.carbon.coop/t/thermal-imaging-as-a-tool-for-retrofit-evaluation/35)._
