Octopus Cozy Cooler
Given the announcement of the Octopus Cozy Cooler does this change people’s opinion on the use of Air to Water Heat Pumps for cooling?
If the Octopus system is able to keep the cold water above the dew point without any structural changes to an installation this suggests that other AHSP would also be able to do this.
For example my Ariston heatpump has humidity monitoring on the internal thermostat and has settings designed for use with UFH with a minimum flow temperature set to 18C or higher. This seems very similar to what Octopus would do with their system.
My ASHP can switch to cooling mode by basically one touch on a touchscreen.
We used it this summer.
However, we have to turn off the heated towel rails as water just poured off them!!
I’d assumed it was a standard feature you could run the heat pump in reverse and turn your radiators into cold lumps when it was hot… is this not the case?
For most of the duration of the BUS Grant scheme heat pumps with an ability to cool were excluded so sales were negligible. That condition has now been dropped and several makes and models can be converted by a firmware upgrade or changes in dip switch settings, however extreme care is required to ensure that the cooled pipework and radiators do not gain condensation. Also as radiators are generally at floor level and cool air falls radiators are not good conveyors of coolth, hence the need for fan coils.
