# Heat pump installers
**URL:** <https://community.carbon.coop/t/heat-pump-installers/455>\
**Category:** Home Energy Systems\
**Created:** [13 April 2022 10:33 UTC](https://community.carbon.coop/t/heat-pump-installers/455 "2022-04-13T10:33:30Z")\
**Posts on this page:** 1\
**Showing post:** 10
<div class="post-metadata">
**Author:** ![Tim\_Gilbert](https://community.carbon.coop/user_avatar/community.carbon.coop/tim_gilbert/32/233_2.png) [@Tim\_Gilbert](https://community.carbon.coop/u/Tim_Gilbert)\
**Post date:** [14 July 2023 19:09 UTC](https://community.carbon.coop/t/heat-pump-installers/455/10 "2023-07-14T19:09:36Z")
</div>
When choosing a radiator look at
> [@Old Radiators - How Many BTUs Radiated?](https://community-new.carbon.coop/t/old-radiators-how-many-btus-radiated/712/1):
> In considering room heating-requirements, I can work out how many BTUs are needed, then find a modern, efficient radiator (or two) that would supply the required BTUs of heat, preferably at the lower heating-water flow-temperature of about 55degC (referred to as ‘Delta30’, apparently.) But, can I know for definite that this would be a significant improvement on the quite-old (1960s?) radiators that are already in situ? Ie, what’s the typical heat-output of an older double-radiator, say 1900mm …
With a heat pump a radiator cannot be too big. Aesthetically I expect that it can!
_[View the full topic](https://community.carbon.coop/t/heat-pump-installers/455)._
